Pdelcast
Pdelcast's Avatar
10.01.2009, 12:04 PM
So, in your opinion, would it be adviseable to run no more than 4s or 5s when braking is enabled in a heavier and/or highly geared vehicle? Since the rise in voltage is at least partially proportional to the supply, this would give a little more leeway before the avalanche occurs.
No, I'd suggest running BIG, high quality batteries. The best way to prevent voltage rise on the bus is to have low impedance batteries.
Lowering the voltage is an option, but the batteries are more important -- insufficient batteries will cause high voltage rise on the line even with lower voltages.
Thanx!
Patrick del Castillo
President, Principle Engineer
