J57ltr
10.01.2009, 02:14 PM
Brian - Effectively that is what the Novak Transcap does if i'm not mistaken...
http://www.shopatron.com/products/pr...ber=5685/135.0
Description
This is a Power Trans-Cap Module for use in high-voltage applications with an input voltage range from 4S to 6S Li-Po. This module includes an 1,800µF power capacitor rated at 35V and includes two transorbs to reduce ESC temperatures and provide protection for the ESC. This module is factory wired with 4 inches of red and black 16-gauge silicone wire, and solders directly to the ESC’s positive and negative battery solder tabs. Module is rated for use with 4-6S Li-Po packs. Exceeding this input voltage will damage the module.
I'm not Brian, but that's what it is and what he was talking about earlier. The cap is there to smooth ripple and the TVS's clamp down on the voltage to a safe level.
Jeff
