FastXR
10.01.2009, 05:06 PM
Originally Posted by stum View Post
Those velineon are fine motors for this application. IF you snap the smaller 1/8 shaft it's cheap to replace. Mind you I said IF, as the likely hood is low. The medusa are awesome, but use the velineon and enjoy it, it will do you well so long as you keep it geared 35-38mph range which is plenty fast for bashing or racing. High speed asphalt runs obviously can be geared up but that's another story.
Thats good to know, I will stick with the velineon motor for now then and hopefully I wont have to worry about gettng another motor.
I did not have much success with the electrifly motor that i tested, although others have had success... Look on rcgroups and offshoreelectrics forums, usually you can find a deal on the smaller neu 1506 and 1509 motors. Not sure of OSE still has the 15 series neus on sale, but that is worth a try as well.
Linc thanks for the tips I will keep my eye out for a Neu or look for one if the VXL breaks.
