10.04.2009, 08:20 PM
Nope, not the way your thinking I'm afraid. An outrunner is just an inrunner turned inside-out. One piece shaft, full length. Excess shaft can be cut off, but the shaft needs the collar on the stator end, that's the main thrust bearing. The front bearing is only for alignment, it sees no lateral load.
