10.05.2009, 12:45 AM
Well, what motor and voltage do you plan to run? If you are going with the castle 2200 motor on 4s, you can run something like the std nitro clutchbell, which would be around 13t.
A little more info on your setup, and desired use/top speed would be very helpful in making a gearing suggestion.
