bigabike
01.24.2006, 02:52 AM
Originally Posted by nitrostarter
I'm having a problem with glitching and blowing up gears. I thing the tranny case is flexing a little and the gears are not meshing right. Do you guys think a single speed conversion might help this problem? I stay in second gear anyways.
I would think it would help. I just installed the gmaxx kit tonight and the aluminum is stiffer and it eliminates length of the input shaft. Shorter would be better for less flex. There are other bennies as well. one less servo and much fewer moving parts in the trans.
Later
