Beanie
10.07.2009, 05:29 AM
Originally Posted by jayjay283 View Post
my take: thats all you need bro. CC 2200 KV a 6500 should last you 20 min. my 5000 does if im not balls to the wall. Use Brian Gs calc, a 14-15 tooth pinion-ish.. I had the Tekno. IMO only its crap, The mech. brakes blow and even their racers changed to direct drive long shank pinions which blow too. LOL (bet I get yelled at)... Losi turd also, get RCM Mikes 8 adapter and one of his or one as nice battery tray. If you check my posts I have an 8T thats pretty sick, mikes motor mount is the key, the slipperential would be so nice and a motor saver but I broke the budget. What you picked out is good you will smoke nitro.... I like running the 2200 on 5s though =D
Really appreciate the advice JayJay, I read your build thread, looks very nice! Sounds like I didn't ought to worry about Tekno kit/mechnical brakes/clutch then....although the slipperential thing sounds like it might be prudent...or again am I just worrying too much
Understand the slipperential, but what is a motor saver?
Thanks again...
