sikeston34m
sikeston34m's Avatar
10.07.2009, 10:01 PM
I've been looking at this one guys, 400 kv, 8mm shaft http://hobbyking.com/hobbycity/store..._(Eq:_4030_AXi)
What are your thoughts on that on sikes?
Zp I wonder if 1mm wall is enough? Then again going to a motor with a 10mm shaft will bump up the weight and size significantly. Just thinking about 2mm would be better for a hollow shaft.
That's not a bad looking motor. A Much cheaper alternative. When you go cheaper, you make compromises though.
Hmmm.......the hollow shaft idea?
Take a look at the counter rotating double motor setups:
http://www.maxxprod.com/mpi/mpi-266.html
I'm sure we could get a hollow hardened shaft for one of these applications. Tried, tested and true, I'm sure.
