10.08.2009, 01:12 AM
Are the motor wires soldered? If so, check for cold joints and/or resolder. If the ESC is connected to the motor via bullet connectors, check to see how tight they are and if they are dirty. If that looks good, I would suspect the motor. Those wires are stiff and can crack the individual strands from repeated bouncing around in a vehicle. Try a different known good motor if you have one.
