Gee
A Horse's Ass
Gee's Avatar
10.08.2009, 09:17 AM
Thanks James. I agree coming up with different alternatives or solutions for the different rcs has been whats helped keep my interest. Getting it done with just what's laying in the parts box(s) is another challenge. Unless you knew it was coming and planned ahead.....
Thanks for the tip on the ofna center diff guys. The only one I've had was the Ultra MBX (maybe). It had a smaller 4mm shaft that was seperate from the gear and the output cup. Just a piece of 4mm steel with a hole in one end and a flat spot on the other. I will search for the ofna cups you are talking about, but if they still pop out after this fix. I am thinking I just shorten the arms a little.
MisterCrash, that is good to hear about your first set of bulks. Well maybe not good but I do feel better now. It makes MisterCrash more human vs the machine that gave us the "revo" thread that everyone should read. Perfect looking bulkheads and precisely trimmed lst cases in one sittting. Now I know there is some trial and error behind the curtain. lol
I looked at your photobucket a couple times (real helpful) before I started on mine. Then looked again during and wondered how your bulkheads turned out so nice. "Must have more patients then me, or maybe he's a machine!" I thought. A nice job on the lst cases by the way. Looks like a stock black one from the pictures.
I was curious just how much would be needed to be removed from the bulks without having to alter the cases any. Well that curiosity is satisfieed. A lot was needed. Your method looks to be easier and a cleaner way to do it.
I've read through the revo thread of yours several times. Nice post and great ideas. The tips have helped me out, thanks. I had my lexan scrap peices all picked out to make some diff blocks like you did, but a slip of the drill and I haven't needed them yet. The screw downd method had been holding up excellent so far. I haven't even ran a full pack through it yet..... lol
I don't have any races riding on my setups so I figured I would give the skeleton bulks and screw down method the abuse test and see how it holds up. THe lexan pieces are sitting by the the other bulkheads just in case.
Lincpimp has come up with some great ones for us. He's gave me a lot of help when I needed it. Hell, I can even go to the grociery store again. Thanks James. The list of different RCs he's had has got to be 3 times longer then the list for his......
I put the link to the original thread at the begining to let everyone know where it all started and who to blame if it doesn't work for them. With the original thread in the General Disc forum, yours in the Revo section, and "It's Me"'s lst in the Maxx thread in the maxx forum. I figured the gorilla maxx forum needed one. That should either make them surrounded or at the least mean our wagons are in a semi circle. You never know when the midgets will be coming to get their pony back.
I was able to sqweek another mm or so for the shaft and cup problem that came out of the install. The backs were easy just crank the knuckles down then back them out one or two turns. Actually, you could dremel a little area for the ball to recess into and eleiminate the rear camber. Nah....
The fronts were more of a problem, cranking the knuckles down just eliminates your steering completely. I shimmed the axle so the steel shaft didn't slide out towards the tire any. Also removed the boots off the new knuckles, the old knuckles did have them. I cut off the little nub on the the knuckle that the boot retainer clips into. I also had to put a notch in the top arm of one of them. My front diff is not exactly sitting at 90 degree. One side is slightly lower then the other. Not by much but enough for me to dremel the end of the upper arm so the knuckle has some range of movement. Should be plenty strong with the ball screwed into the arm as far as it is now. I don't get the full steve hayden lock anymore on the steering but should be enough to turn around in the street without having to use reverse. I will give it a hard time tomorrow and see how it works. There isn't a hole lot of material on the stock arms, I have the RPMs installed an they have a lot more material surrounding where the ball gets screwed into.
It's going to be nice to not hear that clicking coming from the stock differentials. That was a dreaded sound because I knew I was going to have to open it up again and replace it, again.
Okay, here are a couple pictures. Pardon the typos in the comments. I must of nodded of while typing again (old work habit). They are a PIA to edit them once they are saved so I didn't fix them.
Nice tidbit about the mayflys digestive system or lack of. Gotta love/hate those "Absolutely Usless Trivia" popus from the old VH1 days..... I didn't find the light posts or cars on the back of the new 10 dollar bill. Will have to check when and old one come my way. Anyone check your Canadian currency for them?
