Originally Posted by Jabe
Im asking in general.
But my plan is to put it in XT8 with 4S or 5S probably 4S.
Are those sensor cables standard? I mean can i use e.g. Tekin esc and LRP motor?
Most sensor cables are std, however I cannot see using anything other than the tekin motors. You plan to run a truggy on 4s, you will need all the torque you can get. The 2 pole novak/etc motors are not as good as the tekin. Any reason you have to have sensored?
