MMPro Observations
MMPro Observations - 10.09.2009, 12:43 PM
With Patrick's permission, I can now talk about the results from beta testing.
First, some naked pictures of the early testing unit I got:
Some highlights:
  • As you can see, the MMPro looks like a MM/MMM hybrid: the wiring layout is similar to the MM as far as the power/motor wires and status LEDs, but the throttle/switch wires come out one side of the case, the fan and sensor ports are on the other end. The PCB layout is similar to the MMM in how the controller PCB is mounted to the power PCB.
  • Motor and power wires are 13GA, just like the MM.
  • The MMPro physical dimensions are VERY VERY close to the MM, just a little taller (due to the fan).
  • Castle Link has all the functions/features of the MM/MMM, and adds additional features for the sensored functionality. I never tested sensored mode though.
  • Allows sensored and sensorless operation. Sensored mode has a cheat function, but since I never tested this ESC on a sensored motor, I can't comment on it.
  • Adjustable switching BEC. Sweet.
  • Link uses the standard Castle Link adaptor that every other Castle ESC uses, except the MM.
  • Rated for 6s and around the same current as the MM (~80A), maybe a bit more.
  • Three 220uF surface-mount style caps; 660uF total.
  • Fan is replaceable without having to disassemble the case.
Now, let's go over the FETs. Some common choices:
4108 - Used in a lot of ESCs still.
4833 - Used in the HobbyWing 150A and the Tekin RX8 IIRC.
4933 - New OnSemi FET with better power than the 4108 and better switching characteristics than the 4833 (more efficient switching action=less heat). I can't find the datasheet for the 4933, so I can't go into the specs. If someone could find it and provide a link, I would be grateful. The OnSemi website doesn't have it listed at all, nor do any of my normal datasheet resources.
Anyway, the MMPro uses 18 FETs; 15 under the heatsink, and three on the other side of the power PCB just under the throttle/siwtch wires. By comparison, the MM has 30 FETs and the MMM has 36.
The first beta ESC I got used the 4108N FET. Very common FET used in a lot of ESCs. The second unit I got uses the new 4933 FET, and I believe this is the FET that will be in the final product. Patrick can comfirm this.
When my first beta unit came in, I installed Deans and new bullet plugs to match the CC motor (the ESC came prewired with 4mm short bullets), and downloaded the beta Link software and hooked it up to check/change my settings. Since it was nighttime, I then ran it in my e-Jato conversion (CC4600, 3s lipo, geared ~50mph) in the basement to get a feel for it. Seemed to run fine except for this one spot where it went forward a few feet, stopped (lost all power), and then kicked back in, but ran fine the rest of the time. The Eagletree showed a large 105A current spike at that time (normal spikes ~60A). Temps after a gentle 15 minute run were pretty high I though, but I was doing a LOT of partial throttle running. The next day (or the day after), I took it outside for a while and ran around the yard doing high speed runs and general bashing. Ran fine except a few spots where it would hesitate when slowing down and then get back into the throttle. About 5 minutes into the run, the ESC started running oddly and a second or two later, the dreaded smoke came out.
A couple weeks later, my second beta unit arrived (using the 4933 FETs). Put it back in the e-Jato and ran a LOT cooler. Then ran it in the CRT.5 on 3s and it ran cooler than the MM in that as well. Of course, I'm sure the fan helps. Still had that occasional hesitation in mid-acceleration I had with the old version, and when I looked at the ET graph, noticed current spikes over 130A. But this time, the ESC didn't smoke. The new FETs are definitely better.
Eventually, I got a notice from Castle saying there was a hardware and firmware fix to address the hesitation/cogging. I installed the new firmware, but still haven't sent it back for the hardware fix. Regardless, the hesitation seemed to be gone, but it never was a problem I could intentionally reproduce anyway so not sure if it was just a coincidence. I plan on visiting CC next week while on vacation, so I'll bring the ESC for the hardware upgrade.
Since then, I've run it without the fan and it compares to the MM as far as temps are concerned, maybe a tad cooler. I plan to run it with the fan (for warranty concerns), but it's nice to know the ESC can remain thermally stable if the fan unknowingly fails.
Aside from the e-jato and CRT.5, I've also run this ESC in the following setups:
- Slash truck; Medusa 36-50-2200 on 4s geared for ~40mph. Ran perfectly fine with cool temps, which is to be expected given the vehicle weight/size/gearing and motor kv used.
- MBX5/Corr truck; Neu 1512/2.5d on 5s geared for ~45mph. Worked perfectly fine on this too, but that little fan got a workout! I expected it to the MMPro to get hot on this setup though, but it still held up fine. To be clear, I do not recommend running a setup like this on the MMPro, but it was my job to try to kill it after all.
All in all, I am quite pleased with this ESC.
