Originally Posted by naynay12
Instead of starting a new thread i will post here.I am about to buy the mamba 2200kv motor,though it is the e-revo one.Is it the exact same as the flux motor,so it will clamp into the flux mounts?Also the flux motor has a heat sinksand the e-revo one doesn't will that be fine,or will i need to buy a heat sink?
the e-revo motor will not fit the savage flux mount. you can use a kershaw designs mount though. it is only $20 on kershawdesigns.com. you have to look in the motor mount section to find it.
