10.11.2009, 10:55 AM
Differential Ratio: 1
Transmission Ratio: 2.727272727272727
Other Ratio: 1
Spur Tooth Count: 58
Pinion Tooth Count: 16
Total Voltage: 11.1
Motor KV: 3300
Tire Diameter (inches): 4.3
Tire Ballooning (inches): 0
Motor Current Draw: 0
Motor Coil Resistance: 0.007
Spur/Pinion Ratio: 3.63 : 1
Total Ratio: 9.88636 : 1
Tire Circumference (inches): 13.51 inches (343.12 mm)
Rollout: 1.37:1
Total Motor Speed: 36630 RPM
Vehicle Speed: 47.4 mph (76.14 km/h)
Effective KV Value: 3300
KT constant: 0.41 oz-in/A
I would work around that kind of setup- maybe a smaller pinion or larger spur- all the emaxx 3905 ones will work + the jato3.3 ones (54t upto 68t).
http://www.scriptasylum.com/rc_speed/_top_speed.html
