Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
10.16.2009, 01:19 PM
Originally Posted by AMorgan View Post
Guess I should have added a bit more. The CD, FOC and standard forward gears are all the same ratios. So the Revo transmission with CD, FOC or forward and reverse will have the same ratio with the exception of the standard, narrow or wide gear sets, which as I mentioned above, have no effect on the CD, FOC or standard foward gears. Regardless of the CD, FOC or forward gears, you'd choose 2nd standard if you're using the standard ratio gear set or narrow or wide if you happen to be using those gearsets.
Thank you for solidifying the info that was given to me via another source, now I know I'm on the correct track. I will be finishing my battery tray here shortly then final assembly. Due to excessive rain no testing today but the build should be complete and that'll make me happy. I hope no rain in the forcast for Saturday cause I'm hitting the track
I'll post some pics later today.
