ta_man
10.17.2009, 10:55 PM
Two comments:
First: You should be aware that if you are running two separate 2S packs with the HV Maxx ESC, one will get drained faster than the other and you should use a 2S smart stop on that one pack. The way to tell which gets drained faster is to connect a pack to input "A" and try to rurn on the ESC. If it lights up, that is the one that gets drained faster. If not it is the other one.
Second: I've taken apart a Novak BL motor, including the back where the sensor cables go. I've replaced antenna wires and PWM input cables on ESCs but there is no way I would be able to replace the sensor wires on the sensor board. It is just really convoluted in there. Good luck. If you can't do it, your only real alternative is to use their non-warranry replacement option for around $55 (including S&H).
