10.19.2009, 01:02 PM
Originally Posted by schofield View Post
ok so it is over kill. thank you. i kind of figured that but i had seen a car someone made into a snow vehicle with a 4 link system and solid/locked rear.
i wish i knew where that pic is it was out of some old RC magazine. it was really long. so i thought i could use the way an arm is connected and not have the side to side say a crawler has. my thinking is the was snow is all aver the place an not just smooth so i wanted the rear to be able to soak up bumps but then have each arm be able to move on their own to make contact with any random hole
Just use a turnbuckle instead of a shock on the rear tower to arm connection to "lock it out" and then you will solely be using your hinge suspension which I believe will be better for a snow machine.
It looks fun!! I got stuck all the time, but I was in deep snow.
