BUSAFIED
10.19.2009, 11:36 PM
Originally Posted by Jason View Post
here my shock setup it wont work better then the stock shock for me .. when I run over bump the rear end goes up in the air and sometime flip and it REALLY dont do jump fine...
front shock is electric revo aluminium body and titanium shaft white soft spring with piston black 2 holes and AE 35WTS SHOCK OIL.
rear shock is front jammin X1-CRT shocks with white soft spring + white 2 holes piston and AE 50WT SHOCK OIL.
there's your prob right there, Jason...
for the revo front shocks, use the Jato pink springs and the #2 piston. You can vary your shock weight from 25-27.
In the rear, use the soft springs for the buggy front and use 25-27 weight oil.
Another option that I found that works pretty darn good is using 1/10 Stadium Truck shocks (preferably aluminum) in the rear with the .5 blue springs and about 35wt oil.
feel free to PM for further info. :thumbsup:
