Ross
10.20.2009, 05:29 PM
If you are getting the RX8 and Tekin motor combo, you can run sensored and use a lower kv motor than normal; just gear up a little. Shoot for ~28-30rpm. If using a non-sensored setup, I would shoot for ~35k rpm.
The RX8 is the combo that i like the look of most, so yeah it probably will be this one. Sorry, another noob question, why can i run a lower Kv if its sensored .
Ross
