JThiessen
JThiessen's Avatar
10.21.2009, 03:20 PM
Jerry - per the MT speed rules your body cant cover the wheels, so he's stuck with something close to standard width. He may be able to extend one out to almost touch the wheels though.
River - I would almost think that a light diff fluid may help with the torque steer. If not, you may have to get good at setting up your chassis to compensate. I'm going off memory here - can you adjust the maxx arms front to back at all? You may have one wheel sitting slightly forward of the other which could cause a slight drift.
Maybe also try adding a shim to the spring on the uphill/crown side of the truck.
