Yes, but...
The adapter board you linked to seems to be for purely balancing two packs in parallel, not for normal balance-charging. What you need to make, or find, is slightly different:
http://www.scriptasylum.com/rc_speed/_lipo.html
scroll down to the bottom section, and select '2s + 2s' option- you will see the balancer harness has been tweaked so that the charger sees a 4 cell pack, rather than 2x 2s packs in parallel (same too with the main power leads).
