redshift
RC-Monster Square Tube
redshift's Avatar
10.26.2009, 07:24 PM
I had forgot you mentioned the R trigger and such. The foam pad on the standoff mount seems to induce vibes rather than dampen them. That's one thing you'll have to play with on each different cam or vehicle, but rule of thumb is direct mount first, then mess with foam etc. if needed.
If you wanted to eliminate the interface you could either solder to the pins externally on the back of the cam, or better yet, directly to the inner wiring. I'm telling you this up front because the standoff mount was a total fail on my truck lol. The cam just flopped like crazy, made the video useless. AND I even tried some 3M industrial velcro (grey) and that was too thick also and acted like foam. So finally I used only high grade black velcro, and that was the ticket. Only took like 3 videos to get it right, not a big hassle, and gave me some practice both using the cam and saving files.
Good luck with your build, should be a good video mount!
