Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
10.27.2009, 07:49 AM
Originally Posted by Byte View Post
I know his stuff. I got his 2-speed 5mm for my LST.
The motormount from him looks good, but it won't fit an Bigmaxx and I think it's a bit overprised.
I use the stock LST1 wheels/tyres.
@Bondo, If I buy those HD axles, I also need the LST2 hexes right? The LST1 hexes won't fit I think...
The mount is expensive yes, but worth every penny due to being well made.
If it doesn't fit a Bigmaxx you should email him and ask, he might be able to accomodate ?
If you can make HD mount yourself as mentioned in a prior post of yours,do it ! Save some $$
LST2 17mm hubs
http://cgi.ebay.com/LOSI-LOSB3516-WH...item3ef4b31c62
20mm hubs,stock LST2
http://cgi.ebay.com/Team-Losi-LST-XX...item4a9ba96dd6
23mm hub that will fit LST2
http://cgi.ebay.com/NEW-CEN-GST-7-7-...item4838024b91
