Rivermaxx
10.29.2009, 01:26 AM
Yea. I think I am going to change it again its too busy and I can make it alot nicer and simpler. The addition of the mono block and the adaptor and billet block added alot of weight I dont want. So I am going to make a new one peice carbon fiber plate for the top and something for the bottom skid.
Jerry if you look at the pic you can see there is about 1/4 of an inch of space between the body and the ground. I need some space because the suspension does travel some. As it is it should work out fine and the front of the body and windshield should provide the necesary downforce needed. If not I will add the wing or a splitter of some sort.
