11.01.2009, 10:50 AM
Tekno makes a pretty nice conversion also.
Their kit replaces the entire chassis. I'd recommend going with the long shank pinion (over the clutch system) - and make sure you get the longer of the two battery trays.
If you go with theirs, you need to know which motor you are going to run - the motor fits inside the mount, instead of just being face mounted.
