Originally Posted by Byte
Where do you find those Waterproof versions?
I always asked myself what the difference is between the E-Series and Z-Series. The only thing I know is that the Z-Series are newer than the E-Series, right?
The waterproof version is an option you need to ad to the ESC once you picked out the rigth one.
http://mgm-compro.com/prod_opts.php?...&prod_type=reg WR, water resistant version. A picture of this version is at the home/introductionpage of MGM compro. And yes, it also works under water... but other systems of your RC8T might fail to do
The Z series has an extra port for adding a black box to log all data, for that somewhat more $$$. Otherwise equal so if you are not a 'tech freak' it is a waste of money.
