sikeston34m
sikeston34m's Avatar
11.01.2009, 07:06 PM
After my "glitchy" run, I dissected the non-working servo and found it's control board burnt. Even though, it was the first time I ran it, I may have gotten a bad one. I replaced the bad servo, with another MG995.
After turning the BEC down to 5.0 volts, I just took another run. It did not Glitch a single time. Yes, this is running a Pair of MG995 Servos.
I would also like to add, the power delivery of this ESC is really smooth.
This is a light weight, low slung E maxx using a HC 8 Pole 1600kv Heli outrunner geared 14/52 (31 mph). Temps on everything were only slightly warm. The ESC's fan only came on one time during the 30 minute run.
A pair of 6S 26C 2600mah Kong Power Packs in parallel supplied the juice.
As for me, I believe the problems I experienced were to blame on a bad servo.
