11.02.2009, 05:14 PM
radio works fine and the esc is otherwise working fine. I did an update to reassure all setting correct. Motor screws were correct. The solder connection were a concern of mine too. I checked the bullets and they are solid. I dunno about the ones that go into the can. I have yet to crack a mamba motor open. I can say that in testing the motor wires heat up quickly, if this helps at all.
