11.03.2009, 06:09 PM
I would say 0.003 ohms or less per cell. To get overall pack resistance, simply add up all your cell resistances. Again, the lower the better.
Don't forget, the cell resistance from discharging at a low current will probably be higher than discharging at 100A. The resistance curve is not linear. It generally decreases somewhat as current goes up until you hit the dicharge limit of the cell, at which time resistance climbs fast. Also, towards the end of the discharge cycle, resistance starts to climb as well.
