ANGRY-ALIEN
ANGRY-ALIEN's Avatar
11.05.2009, 11:21 PM
Not a bec issue as such, though running an external one always helps with older style escs. Sounds alot more like thermalling- the heat spreaders & thermal tape tend to let go after a while, then there FETs have no way of transfering their heat to the case which is also the heatsink. Cogging sounds more like either a gearing issue (too high maybe?), or just the software perhaps- not sure if its possible to update it without sending it back to Quark.. good luck that one... :/
Neil... I opened the esc today and found that the thermal tape was not sticking to the casing the way it should, 1/3 of the pad is covered with dirt, leading me to believe the FETs were overheating quite a bit... I am hoping this is the worst case... I am also thinking cogging is attributed to gearing... Mike shipped the new pinions for me this week, so I hope when I get everything back together the smaller pinions will help to reduce cogging... Is there an easy and safe way to remove the heat spreader from the FETs... and if it's really stock on there... should I bother to remove it?
I thought the bec was only good for up to 4s then you needed an external one above that voltage. Which might be causing the esc to thermal more often. I wouldn't say it is the only reason it's thermalling, just it's not helping.
Hey Pinkpanda... I'm actually using an external BEC... I clipped the red wire on the receiver lead to disable the internal BEC.
A few pics (I hope it's ok to post photos here):
