Kcaz25
Kcaz25's Avatar
11.09.2009, 12:50 AM
Thanx, Neil yeah hot glue is what I used. ESC still works great, just gets hot without the fan. I'm thinking about cutting the top of the case off to expose the heat sinks alittle, whats the public opinion on that? Not gonna jump much until I can get 4 more super shocks for the sake of the poor ESC getting raddled again.
Lookie:
40 Series Mashers rapped around
Weld racing zero off set 23mm hub 40 series Cheyenne wheels
This is how I justified getting them incase you are wondering. I posted this in that other forum a few months ago.
Originally Posted by Kcaz25
Thinking about getting some 40 series mashers since my drive train is as just about as beasty as it gets I think I can handle it and I want more ground clearance but can't get much more with the suspension because the shafts pop out of the cups and get all bent up. Plus when I get my slipperential installed I'm going to want to gear up and the big tires will really help. Also I don't think it will look goofy because my wheelbase and stance are big. Big tires for a big truck! And maybe they won't slump to one side like the badlands do currently.
This is as good as humanly possible. Really wrinkly, ticking me off a bit, however after testing it I found it to be perfect. NO MORE Ballooning!
I love this image! Can you figure it out?
Tight heavy duty rubber bands to help in the glueing process.
See the crome hub cap on the wheel to the bottom right? Pretty neat, probably gonna run without for practicality sake.
Still the blue 23mm nut the the upper left corner looks pretty rockin.
More pics 2moro, I cleaned the truck body.
