jhautz
jhautz's Avatar
11.10.2009, 03:59 PM
Run the same oils as you used to run with the stock diffs. The diff in the slipperential should give you very similar driving characteristics as your stock diff (probably exactly the same). The only difference being the added benefit of the slipper clutch to tune a bit of low end punch and absorb shocks to the drivetrain.
to make it...
or break it...
Silent...But Deadly
