nitrostarter
nitrostarter's Avatar
11.11.2009, 02:15 PM
I used to heat the LiPo's up for running them in my boats. It made them more responsive in the beginning and provided cooler temps in the end of run, and that's dumping 4500mah in less than 5 minutes...
I used a heating pad that plugs in the wall. Just turn it on, let it heat up, wrapped the packs in the heating pad and then monitored the temps. I usually got them to about 105*F before running them. Worked great!
I also dig the solid black. Lets hope you can keep the tires on the ground and make some clean passes.
N. Rustler conversion
