maxxdude1234
maxxdude1234's Avatar
01.29.2006, 06:25 AM
Originally Posted by Serum
I am sorry, but 12 cells can do 1200 watts and 18 cells can do 1800 watts. (that's no 100% boost, but 50)
That is quite true, and why I said at the end of my post, that it all depends on whether the batteries can supply the power.
And if you need 1200 watts on 12 volts, it is 100A and on 18volts that is 66.67A, and like i said, if you use the same power, runtime WILL be larger, not smaller. Adding cells gives you more energy, so runtime will increase
That is incorrect, if you increase voltage you increase current - its proven scientific fact. Its not a matter of 'if you need 1200watts', motors do not work like that. I could spend hours explaining why, but its a Sunday and I can't be bothered.
I'm happy to agree to disagree :)
