whitrzac
Can't catch this...
whitrzac's Avatar
11.12.2009, 04:22 PM
Originally Posted by GO-RIDE.com View Post
It only happens at the track, which does have some big jumps. I did a bench test at home and then drove it around on the street for 15 min and it did not glitch, but hit a few jumps at the track and it's a problem.
I'll re-check all the wiring, but it looked good the other day. I think the PCB in the ESC is going bad and it's only a matter of time till it quits all together. Not a big deal. This one has not been in for warranty yet and it is a V1 of the RX8.
it might be the pot on the bottom of the lower board in the esc, there is a known problem with a solder joint coming loose.
5R6 chip on the bottom
