11.13.2009, 05:07 PM
Originally Posted by Kenny135 View Post
I am going to be doing a complete tare down on the truck and going to rebuild it with lots of aftermarket parts. I have graphite extended chassis plates, graphite motor mount, graphite servo mount, graphite bulkhead lower plates and graphite shock towers from Platinum RC Products. I also have Golden Horizon Aluminum Bulkheads, HPI Machined Bulletproof Diff Bevel Gear Sets, HPI High Speed Idler Gear and Shaft Set, HPI HD Drive Gear, HPI Light Weight Drive Gear, HPI Light Weight Idler Gear, HPI HEAVY DUTY SERVO SAVER SPRING, and finally a Hitec HS-7955TG servo. So as you guys can see I'm going to be busy
Looks great! Look forward to seeing your finished truck! Keep the updates coming
