tkhoo
11.16.2009, 05:15 AM
Hi guys, i having new problem on my MM esc. Ok, as you all know my motor is running hot and i went to bought another cooling fan which speed at 14000rpm and fix on the motor heatsink and wanted to try do the motor temp able to drop or not. Yesterday I try up to run on my backyatch and found the steering servo hardly move and found maybe the high speed fan draw more current from the rx and I parallel 2 fans together and get the voltage from rx and I can see when I fully turn the wheel and hold it, the cooling fan will slow down the speed, may I know how to slove this problem?
Another problem is, with above problem i still able to bashing around but ~1-2min, the motor stop running and I can see MM red or orange (sorry, dont know what the colour)LED is blinking. I have to switch off the esc and turn it on back and then I able to bash around again but in ~1-2min the problem came back again. I need help on this.
Oh ya, i also set the punch setting from 80% to 30%. Before I can bash till the Lipo juice finish :) Please advice. Thanks.
