J57ltr
11.17.2009, 10:36 PM
Originally Posted by Rivermaxx View Post
My issue is I am making so much power that when I am on it and the tires just spin causing me to loose control. What good is that? I think if I used a higher kv, smaller less torque motor with higher numerically gearing I would be faster because I can control the car better better. Even with 100 % punch control with my setup it still will wheely if I hit it at a roll. My question is will the esc be able to handle the smaller higher kv less torque higer rpm setup better and be less likely to burn the esc or would it be about the same with the bigger motor less kv more torque motor. What I am trying to get at is you can have all the power in the world but if you cant put it too the ground without spinning the tires and going straight down the track what good is it.
I know what you mean, about having too much power to use, up until recently I rarely made it through a battery pack without breaking something. It usually goes ok until I really start picking up speed then it wheelies and I would end up cartwheeling to a stop.
As far as running a phyisically smaller motor I don't know if that would work, or rather what the smallest size you can use without risking damage to the controller. I have been trying to find the info that said that the MMM wouldn't be warrantied if used with a motor smaller than 70mm in length on a 36mm motor. I think this would be due to saturating the motor at that point the windings would act as a short and damage the ESC. I asked about this but for the MMP but haven't gotten an answer yet. I know the 2200 and 2650are too big and the 4600-9000 are not sutiable for 6S.
Can you use a traction compound like Koford? It might suck up some power but since you are way overboard on power it shouldn't be a problem.
I know you said that you killed at least 2 (was it 3?) MMM's on your last runs. When did they let go at the line? I wasn't real clear on that.
Jeff
