Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
11.22.2009, 03:02 PM
I think the 30seriess are realitively the same as normal 2.2 tires just the wheel is larger with the tire having a lower profile.
The tires are much thinner designed for 4-6lb trucks not a MAXX, They also are designed to be driven on a 12mm hub or a pin on 1/4"-3/16" axles, The Maxx runs on 14mm or larger hubs with 8mm axles shafts. SO, bottom line your shit out of luck,Sorry.
