Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
11.22.2009, 03:09 PM
A-HA !
There is a cut on the 2.4 RX wire also. VERY HARD TO SEE. The TRX 2.4 RX wire is designed like a COAXIL cable with a super thin 5-6strand center wire with the outer wire braided with a semi hard exterior coating that cracks when bent excessively.(junk) The exterior wire was cut very cleanly and my old eyes needed a magnifying glass to see it. It's repaired and working normally. Was a serious bastard to solder, now the antenna wire is on the outside of the tube with a couple layers of heat shrink to protect it. Gonna half to run inside under the body now,but it's all good.
Thanks for the effort guys !
BrainG or other mods, this thread might be of some help to others. If you feel it is not, please delete.
