Thread: Castle 1717
himalaya
himalaya's Avatar
12.01.2009, 12:02 AM
That measurement is on the end cap, the o.d. of the fins will be quite a bit larger. The 1717 (1.7 diameter rotor) will need to be at least .2 inches larger or about 5mm than a 15 series (1.5 diameter rotor), and more yet if they pack more/larger windings in there.
Say 1515,the first 15 is the can dia.(w/o fins), not rotor dia. for instance the Neu 15 series has a dia. of 1.53"(39mm). the latter 15 is the rotor magnetic length.
Originally Posted by rabosi View Post
I think Himalaya is right. In post #11 Patrick show a caliper measurement for the 2025 to be 53.67mm. I did a rough comparison measurement from the photo on page one and it seems like the diameter for the 1717 is around 45mm (+/- 1 maybe?).
Correct. The endcap is about 0.2mm smaller than the can. With fins added the can gets 1.8mm larger, thats exactly 55.6mm shown on Castle website. It's def a 2025.
I was trying to figure out if my KB45 watercooling jackets fit the 1717 and found this on CC website.
....What a Blue Sky....
