doo540
12.01.2009, 10:39 PM
Neil
I just had to post some pics of my TXT-1 with the MMM installed and running. I just hope the MMM can keep up with 2 (2s 5000 30c) in parallel lipos and 2 540 brushed motors. lol I hope you find some stronger axle gears because I have Neu 1527 1.5d (1500kv) that needs a good home. BTW this is one of two TXT-1 that I own, same setup on both trucks. If you look close you will notice that I'm running the truck backwards (lipos in front). Still testing to see if I like that way. Truck has some nasty body lean/roll without the sway bars installed too. I hope to get my extra frame on the CMM machine this week or early next to start designing a longer frame for a extended wheelbase truck.
