Originally Posted by powah
When you look at the picture of the CC Blower you didn’t see a wire for the receiver to power up the fan.
If you wanted to you can route the wires out of site. Just pull the fan wires and plug through to the inside of shroud, then hold the wires down the side of the motor (inside of a row of fins at least three fins from edge of shroud) as you snap the fan shroud on the motor. Doing this leaves a small hole/air leak where the wire use to exit, I just hot glued mine closed.
