diffs?
chrismechanic
diffs? - 12.03.2009, 05:40 PM
hi all...ye, but the shaft dont fall out of the cup, even after its bent. and its not too far in either pin is half way up the cup slot.
its when i tumble over front to rear, then hit outside of rim against the ground the arms give but the shaft cant so it just bends.
so why do i need to fit revo axle carriers to use these shafts? or do you mean the hubs, due to the lager inner bearing?
as traxxas call what i call an inner diff casing they call an axle carrier? but they also call the hubs axle carriers too so im confused by it all...
i trust u mean i need part 4334 for a 3905? yes i know these will have to be changed (i need new ones anyway)
Last edited by chrismechanic; 12.03.2009 at 05:42 PM. Reason: lol. too much power?
