Originally Posted by BrianG
You could encase the whole ESC (up to the heatsink and connectors) in epoxy. THat would definitely void the warranty, but no water troubles .... at least not on the ESC...
But then my worry is heat. If I were to coat it in anything, I'd wrap it up and plasti-dip it, however I think it would overheat due to no airflow and the fan wouldn't be able to even do it's job. I will see what I come up with and maybe post some pics. Here's to hoping I don't kill the speedy!
Edit:
Ahhh I just re-read your post. You mean coat everything except basically the fan? The fan looks like a perfect spot for water to get in to me....
