Originally Posted by JoFreak
Well with the CD-mount from Mike the Slipperential should fit with minimum modifications if any. And there is a shop in Germany which still has some x-braces in stock, which would be the only part needing modifications for Slipperential. And the CD-mount doesn't need any modifications on the G3 chassis at all. So no problems with the G3-extinction here!
The difference I hope for is that I don't have to land my jumps with finger off the accelerator, which would make the car flip forwards due to the brake momentum of the motor. hope you know what I mean there, if not, just get a bigmaxximum (or any 4 pole motor as far as I know) and try to turn the shaft with your fingers...
Have you tried it? I bet its not as bad as you think. Neus are very hard to turn by hand as well.
