JThiessen
JThiessen's Avatar
12.06.2009, 06:31 PM
Originally Posted by Freezebyte View Post
You also failed to mention to use that your driving the Flux in near 0 temperature conditions and snow. Were you not aware that colder temps can make plastic and even metal more brittle and more likely to crack and break vs regular room temperatures. .
He has ignored every question regarding drivng style/conditions - which makes me suspect that the cause of the failures is user induced. If in fact he is running it at 0 degrees F on 6S, then yes, that is the cause of the problems. I would also bet that the traxxas vehicles he quoted would never hold up to half the power he is putting out with the flux.
