$w!ft
02.01.2006, 02:32 PM
Well london is quite a cold place this time of year, so everything was cool. Motor was maybe 20 celcius or something. Rest was cold.
Now for the questions:
What pieces for the slipper do i need? Is 17/51 Gearing ok? Delrin or nylon?
this:
http://www.rc-monster.com/proddetail...od=Slipper-Kit
and
http://www.rc-monster.com/proddetail.php?prod=ofn30110
and some of this? Fits the 1930?
5mm bore, mod1 pitch pinion
Use these pinions on your motors that come equipped with a 5mm shaft. Excellent for use on the ofna spus gears used on the strobe slipper assembly. Not recommended for use on metal spur gears. The 10 tooth pinions have a 6mm bore and includes the needed bore reducer.
Oh and where in swizterkand are you Dafni, I go to Gstaad and geneva about 3 times a year.
