Dafni
Dafni's Avatar
02.01.2006, 03:12 PM
Correct pinions! Nylon spur will do. Gearing depends on your wheels, too. I would get more than one pinion. Maybe an 18t for you.
You only need the spur and the strobe adapter (it comes with a set of pads and bearing, and you can use the stock slipper plates and spring)
