Re~Mix
ĄGo Baby Go!
Re~Mix's Avatar
02.01.2006, 08:18 PM
Might want to run a little more voltage through that motor, I'm guessing thats its a 8L w/ 1/8th shaft or so, due to the specifications. A novak brushless would give you better speed on 6 cells, and since it's a 1/10th truck I would opt for motor with 4200-5300kv or so if you're running 6-7 cells. The lehner basic's are perfect for this application, and the feigao 380c L versions would work too. The L 540 motors are just too big, as the S would be more ideal.
RC18T FT - Quark Castle Creations Airtronics IB
  Send a message via AIM to Re~Mix
